2000 Ford F350 INjectors wont pump fuel
2000 FORD F-350
1,000 MILES • V8 • 4WD • MANUAL
DANIEIL31
The injectors in my truck wont pump fuel into the engine i would like to know if they have a relay for the injectors or if its something else i would greatly appricate it o by the way its a Diesel engine thanks [img:e549200302]http://www.2carpros.com/forum/automotive_pictures/203886_2002_ford_f350superduty_4192E_1.jpg[/img:e549200302]
Jun 19, 2008 at 1:00 PM
KHLOW2008
  • 41,814 POSTS
Hi Danieil31,
If the fuel pump is not sending fuel to the injectors, either the fuel pump is faulty or the idle control switch is not working.
Check the wire connector behind the fuel pump for power supply, if yes, remove the solenoid switch and test if it works. Check for iron filings, if found, the fuel pump is faulty. Clean the solenoid and remove any filings with a magnet and replace solenoid. Try starting again, should work but it will come back.
You need to have the fuel pump serviced.
Jul 6, 2008 at 6:06 AM
