2001 Ford F-350 volume control in speakers
2001 FORD F-350
155,000 MILES • V8 • 4WD • AUTOMATIC
HOOFINROUND
My factory speakers finally blew out in my 2001 Ford F350 Diesel. I purchased new speakers and installed three out of 4. It seems when I put the 4th one in, it will pop anytime that the key is in the ignition and when the truck starts. Also, the other 3 speakers are fluctuating volume (will get loud then quiet then loud), while parked or driving. It worked fine before I hooked up the new speakers, so not sure if it is grounding out somewhere now or not. What do I do?
Nov 2, 2010 at 11:56 AM
TECH1FORD
  • 102 POSTS
do you have the factory cd player in it now.
Nov 3, 2010 at 2:34 AM
HOOFINROUND
I replaced the factory cd player with another factory cd player about two years ago because the old one kept scratching my cd's and making them skip (the player in the truck is a cd/tape deck/radio combo). I haven't had any problems with the new cd player.
Nov 3, 2010 at 1:27 PM
TECH1FORD
  • 102 POSTS
sounds for sure a grounding issue, did you have to put in diffrent screws to mount the speakers, might you have screwed through a wire.
Nov 10, 2010 at 1:04 AM
