In addition to the turn signals, the wiper, washer, and headlight dimmer are on the turn signal lever. I have not yet tried the headlight dimmer to see if there is any effect. The OD switch is in the center of the shift lever on the other side of the column.
It would be great if you will be able to tell me where the wiring comes together, and what firewall connector is used. I see two firewall connectors that I can get to from the engine compartment if I need to. I don't know if there are others.
Thanks in advance.
Rod Swenson
Wednesday, December 19th, 2007 AT 2:03 PM
