1997 Ford F350 Backup Lights and Cruise Control
1997 FORD F-350
178,000 MILES • V8 • 4WD • MANUAL
1997POWERSTROKE
Hello i have two questions. 1) The person i purchased my truck from had the cruise control disconnected and i was wondering how would i reconnect it so i can use it. 2) I have changed my reverse light bulbs and checked my fuses. Is there anything else that i can do besides tearing into the wires? Thank you so much
Feb 11, 2010 at 8:28 AM
BLUELIGHTNIN6
  • 16,542 POSTS
for the back-up light issue, suspect faulty back-up lamp switch located on top left side of transmission
are you certain the cruise was disconnect on purpose or it just doesn't operate? check the fuse for the CC circuit. do your brake lamps work?
Feb 11, 2010 at 11:21 AM
