2001 F-350 7.3 Diesel wont start/ Relays buzz
MGLCDR
  • 2001 FORD F-350
I have an 01 f350 7.3 diesel that cranks but wont start. Upon cranking the flasher relay will buzz. I was taken to ford and the changed the cam position sensor, It was fine for about a week. Now its the same old thing.
Can you help
Wednesday, November 28th, 2007 AT 8:49 PM
FSTRANGER302
  • 117 POSTS
Hello, it is possible that the cam sensor is bad again. Does the rpm guage on the dash move when you are cranking the truck. Also check your batterys and make sure you have good voltage. Let me kn ow what you find pat thanks
Wednesday, December 5th, 2007 AT 12:38 PM
