1999 Ford F350 Problem with acceleration
COUNTRY7180
  • 1999 FORD F-350
Electrical problem
1999 Ford F350 Four Wheel Drive Manual
Ok guys Here we go
I have a 1999 Ford F350 Powerstroke with manual trans 4x4
I had a problem with the T.P.S. In the floor conected to the throttle pedal
It would not accelerate I replaced the sensor and it cured part of the problem Now when I put the transder case into 4 high or 4 low I can't accelerate Put it back into 2wd and its fine
I have had it to three seperate dealers and they can find absolutely nothing
Is there another controling sensor Or some other problem
Please Help
Thanks John
Sunday, October 12th, 2008 AT 11:41 AM
COUNTRY7180
Figured it out after many exausting hours
The fuse box under the steering wheel Slot 19 fuse A wire had came out of socket in the back of the fuse box
It really sucked So just to let you know
Sunday, October 12th, 2008 AT 6:07 PM
