I have no power, no nothing
1992 FORD F-350
190,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
HEALTHYWILD
It would not start. I put in a starter celluloid under the hood. It started and would not shift, the gauges and door locks would not work. I put in a new battery and then nothing at all. Checked some fuses.
Dec 6, 2014 at 2:14 AM
WRENCHTECH
  • CERTIFIED EXPERT
  • 20,761 POSTS
Sounds like you may have installed that solenoid incorrectly. There are a number of feed wires that attach to that solenoid that are actually fusible links. Make sure they are installed on the battery side of the solenoid and give each one a little tug to see if they stretch to indicate they may be burned out.
Dec 6, 2014 at 4:41 AM
