Ford f250 crew cab diesel 2005 68K. The truck has a headlight out on the right side but only on the low beam. I have checked the fuse and bulb. Some one said it could be a relay. Where is the relay located for the low beam right side? If not a relay problem is it maybe a short in the wire or what else?
Oct 27, 2007 at 2:30 AM
