1978 Ford F-250 Cylinder Flooding
MTNBOY
I have a 78 F-250 with a 400M completly rebuilt about 15k ago. My # 5 cylinder is flooding With all plugs removed # 5 blows out gas, it has the Edelbrock carb/manifold on it. It just started running rough while driving. Any help?
Mar 3, 2007 at 5:06 AM
CHEVY22
  • 1,375 POSTS
if you have gas flooding in one cyl only , with the plugs out and it still does it , you may have a stuck or damaged intake valve , valve guide ,valve seat , valve spring you could pop the valve cover and see if it is stuck open
thanks
if you are happy with the info please leave feedback we all here do this for free feedback is a way of saying thank you for the help
Mar 3, 2007 at 5:25 AM
Suggested Repair
Inspect cylinder 5 for a stuck or damaged intake valve. Remove the valve cover and check whether the valve is stuck open, and inspect the valve guide, seat, and spring.
Conversation Summary
The owner of a 1978 Ford F-250 with a rebuilt 400 engine reports that cylinder 5 is flooding and blowing fuel with the plugs removed after the truck began running rough. An expert says flooding in only one cylinder may indicate a stuck or damaged intake valve, guide, seat, or spring, and suggests removing the valve cover to check whether the valve is stuck open.
