F-250 Powerstroke Oil Pan Gasket Replacement
SBALDWIN
  • 1925 FORD F-250
Can you give any instruction on how to replace the oil pan gasket in a 2000 F250 7.3 Powerstroke?
Thanks!
Wednesday, April 4th, 2007 AT 11:03 AM
BOOTDOG
  • 665 POSTS
I will tell you this, I just replaced one on an e350 van and the only way to remove the pan is to pull the motor. You can either take the heads off and then pull the motor, or remove the cab. You see, the cross member is welded to the frame and the sump is so deep it won't come out even if you remove the transmission, flywheel and jacking the motor up. It wasn't a very fun job. Anyway good luck on whatever you decide
Wednesday, April 4th, 2007 AT 3:40 PM
