Engine Performance problem
1984 Ford F250 V8 Four Wheel Drive Manual
I have a 1984 f250 4x4 man.Trans. w/7.5 L. eng. 4brl.carb just had to replace the oil pan gasket. now both fuel pumps = 1in front tank & 1 in rear tank are not working ? They prior to it being parked for a year then towed to were i am now the fues are good the relay has ben replaced and the inursa switch has ben reset. i checked the power to the switch that controls the two tanks there a red wire that is Hot and one yellow wire that is flashing i am at a loss for info. have owend many ford trucks for the past 25 years i do all my own mechanic work ive ben a machinest for the past 23 years however this truck has pushed my limits .
hope you can "HELP"
RESPECTFULY
WRENCHBENDERIOU12
hope you can "HELP"
RESPECTFULY
WRENCHBENDERIOU12
Mar 11, 2010 at 3:36 PM
