Door locks
FORD F-250
CYRUSIV
I have a 2001 F-250 and the auto door locks quit working. The remote and the button inside both give the same result nothing. When you push the lock button it makes a noise like its going to lock and the stem on the door moves a little but dosen't lock.
And each time you push the button it gets weaker and weaker untill it stops doing any thing for at least a min. Same result on all the doors. Any advise would be great.
Nov 12, 2007 at 9:41 AM
GLENSTER
[quote:7fc5b9a345="cyrusiv"]I have a 2001 F-250 and the auto door locks quit working. The remote and the button inside both give the same result nothing. When you push the lock button it makes a noise like its going to lock and the stem on the door moves a little but dosen't lock.
And each time you push the button it gets weaker and weaker untill it stops doing any thing for at least a min. Same result on all the doors. Any advise would be great.[/quote:7fc5b9a345]
I had the same problem with my 2001 f-250 the door actuators have shorted out and you need to replace them you can do it your self , just remove the door panels and unplug the old ones and replace all I had to replace were the front two doors.
Nov 12, 2007 at 6:26 PM
