Please any info or idia's please reply.
thanks hey wire.
With the injection pump installed and statically timed, bleed all air from the fuel system: loosen the injector lines, crank, and tighten each line as fuel squirts. Confirm the external lift pump works, the fuel filter is tight with no air leaks, and the shutoff solenoid gets enough current to engage (hot-wire it if wiring is weak). Retest every glow plug with a test light and confirm proper glow time before cranking.
A 1984 Ford F-250 6.9 diesel with about 140,000 miles cranks but will not start after previously running out of fuel. The owner replaced the lift pump, injection pump, starter brushes, and batteries, retimed the pump several times, and reported working glow plugs, a working block heater, and fuel delivery that still would not fire the injectors. Experts advised bleeding trapped air at the injection pump and injector lines, verifying shutoff-solenoid activation and current, retesting glow plugs, and checking injector atomization and a tight, air-free fuel filter. The owner later returned the injection pump for diagnosis and hoped that was the cause.
