2004 Ford F250 using coolant
2004 FORD F-250
BELGIAN
Engine Cooling problem
2004 Ford F250 V8 Four Wheel Drive Manual
the truck has a diesel engine using coolant. runs fine, no water in oil.
would this be caused by a head gasket problem and if so what would be the average cost to repair this problem?
thank you
May 12, 2010 at 7:24 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Before getting into costs of expensive repairs, lest do a bit of diagnosis first, go get a cooling system pressure test done tis will locate any external coolant leaks, also have the pressure cap tested, start here.
mark (mhpautos)
May 12, 2010 at 10:53 AM
