Ok, it you were able to tap on starter and it start then I would say that it is your starter and if you were able to jumped starter and the bindix spun just didn't engage, I would remove starter and take to local parts store and have them test it.
If tests good look for bad grounds. Check the Neg cable at block for good connection, remove and clean to make sure connection is good.
SPONSORED LINKS
Saturday, August 22nd, 2009 AT 11:08 AM
