1999 Ford F-250 5.4L will crank, but no start
AJT1999
  • 1999 FORD F-250
  • V8
  • 4WD
  • 12,000 MILES
Hello, thank you for your time. The truck ran fine and sat for three days. She will crank and not start. Now, the odometer has dashes with no numbers on it, the theft light blinks/flashes while trying to start it. I noticed the fuel pump relay did not make any noise, nor did the pump, so I jumped the pump in the fuse box, and the pump works fine. I am assuming it has something to do with the PATs system, or the PCM.I did use both keys and that made no difference to the theft light. Is there a way to by-pass that, and if so will the odometer come back.I have studied the schematics for the wiring, and I do know that there is a PATs system by-pass available for purchase, but I am sceptical that it will do the trick. Can anyone help guide me into the right direction with out the use of the dealer? Thank you for reading my post.I am a firm believer for paying for services rendered if they are of value. So, please be honest and so will I. Thank you
Thursday, February 14th, 2008 AT 10:58 PM
MERLIN2021
  • 17,250 POSTS
Three things needed to make it work are Pats system, including the keys, and module, Instrument cluster, and PCM, To check your cluster pull it of and measure the resistance of the LED, in both directions, Resistance should be greater than 10k/ohms in one direction, and 10-20 ohms with the leads reversed, if not replace the LED, if ok replace the clusrer. The best thing to do is to retrieve the B codes stored in the PCM. This will point you to the faulty area.
Friday, February 15th, 2008 AT 9:07 AM
AJT1999
I am happy to donate.I assume I just hit the donate button.I just want to make sure you guys know it. Is for this post and your quick response. It was a little Hard at first but. Ebay carry's just about anything. So I bought an NGS. Thank you. I know you guys are busy. But please let me know, if I just hit the donate button that the person who helped out atleast knows I appreciate their help. Thankyou.
Oh ya. Believe it or not, the "fuse box" under the hood/power control. The connection under the box was corroded. Cut and replaced terminal and works with out reprogramming. Thanks
Sunday, March 2nd, 2008 AT 9:59 AM
MERLIN2021
  • 17,250 POSTS
OK Thanks for the update!
Sunday, March 2nd, 2008 AT 11:22 AM
