Thank you for the message, I will try that in the morning.
Today I tried again to jump start the truck with no luck. I replaced the ignition switch and starter. Again I had the same results. Today I noticed that when the key was turned to the on position I had power inside the truck and the check engine, battery lights were on. When the key was rolled over to start the truck the lights went out and a single click noise came from the starter. Upon releasing the key sometimes there was still power and sometimes not. I then tried to jump the solenoid with a screwdriver across the 2 posts. I got a spark and again the starter clicked once and then I had no power. I also noticed that when rolling the key to start the truck, #1 and #2 relays also made a single click noise. I then replaced both and again had the same results trying to start the truck.
Friday, March 26th, 2010 AT 7:56 PM
