HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-250
Engine
Crankshaft
Rear Crankshaft Seal
Leak
1993 Ford F-250
DROF93
MEMBER
1993 FORD F-250
V8
4WD
MANUAL
230,000 MILES
How big of a problem do I have if I have a oil leak coming from the rear main seal and also have a manifold gasket leak.
Monday, October 6th, 2008 AT 12:45 AM
BLACKOP555
MECHANIC
How big of a leak, if you keep it filled then its liveable with. Lots of engines have leaks there.
For the manifold leak, I would fix that fast, it will decrease your performance.
SPONSORED LINKS
Saturday, November 22nd, 2008 AT 6:51 PM
Please
login
or
register
to post a reply.
Related Crankshaft Rear Crankshaft Seal Leak Content
1991 Ford F250 Valve Cover & Rear Main Seal...
I Have A 1991 Ford F250 Extended Cab Xl, 115647 Mile With 5.8 Liter Engine. I Had It In Yesterday For Normal Service And Was Told That...
Asked by
oldcowiz1008
1 ANSWER
1991
FORD F-250
1960 Ford F250 Main Bearing
Engine Mechanical Problem 1960 Ford F250 Two Wheel Drive Manual I Was Told By My Machanic That The Rear Main Bearing In The Motor Is...
Asked by
andycalton
1960
FORD F-250
Wiring Harness Electrical Connector
Hello, I Am Trying To Replace Or Repair The Fuel Injector Wiring Harness In My Truck. I Have All The Replacement Fuel Injector Connectors...
Asked by
aaronlepine
1 ANSWER
1993
FORD F-250
How Can I Get More Horsepower Out Of My 7.3l Turbo
Asked by
Anonymous
1 ANSWER
1993
FORD F-250
1994 Ford F250 Ecm Or Eec Problems
Hi, I Have A '94 F-250 With A 7.3l Powerstroke Diesel. The Truck Had Been Hard To Start ( Glow Plug Lite Comes On And Goes Of After A Few...
Asked by
olefogy
1994
FORD F-250
VIEW MORE
SPONSORED LINKS
Crankshaft Seal Replacement - Rear
Crankshaft Main Seal Replacement - Front
Flywheel Replacement
Online car repair manuals
