2003 Ford F-150 Surges Under Load
HVBARBIE
2003 Ford F150, Small triton engine.
90K miles
Replaced plugs, cleaned MAS, New Air Filter, new fuel filter, transmission checked.
At Apprxomiately 1200-1500 RPM there is a hesitation or surge. This is noticed moreso when the truck is under a load. The check engine lite is not coming on, I have had to shops check it, one did a "Live scan", unable to diagnosis the problem Of course this is having an impact on my gas mileage. It was suggested to replace the coils, which are quite costly. My attempt to replace #3 and see if that helps, if not move it to #4 and see if that makes any difference. Very frustrated with not being able to get problem diagnosed or corrected. Any suggestions? Thanks for your time! :lol:
Nov 20, 2007 at 2:51 AM
BLACKOP555
  • 10,386 POSTS
Unplug the MAF/MAS does this help it any, if so you should replace it. post back your results.
Dec 5, 2007 at 12:37 PM
Suggested Repair
Unplug the MAF/MAS and road-test under load. If the hesitation or surge improves, replace the MAF sensor.
Conversation Summary
A 2003 Ford F-150 with about 90,000 miles hesitates or surges around 1200-1500 RPM, especially under load, with no check-engine light and reduced fuel economy. Plugs, air filter, fuel filter, and a MAF cleaning have already been done, and coil replacement was suggested but not confirmed. The expert advised unplugging the MAF/MAS and replacing it if that improves the symptom.
