2002 Ford F-150 Front End Grease Fittings
TKELLEY
I own a 2002 Ford F150 4x4 (98000 miles). I am finding 2 grease fittings on the front end passenger side. I just need to know if there are any more grease fittings on this truck.
Thank you for your time.
Apr 3, 2006 at 7:24 AM
LOSONE
  • 1,616 POSTS
The bottom ball joints have a grease fitting as well as the drag link. Often there are grease fitting on the drive shaft. Sometimes the 4WD linkage has a fitting. The factory uses what they consider "lifetime" grease in the front ends, which is usually just synthetic grease. When this is the case, they dont supply Zerk fittings for lubing. Most aftermarket replacement components do however have zerk fittings. Most of the time you have to just look, the manuals dont tell which do and dont have fittings
Apr 3, 2006 at 10:32 AM
REDBUD49107
I've been told I need to "rebuild the front end" on my truck. Is there a recommended parts lists as to what all should be replaced?
Mar 24, 2019 at 4:08 AM (Merged)
RACEFAN966
  • 5,029 POSTS
My list would be Tie rods all and upper and lower ball joints and I would check the sway bar bushings and end links too.
Suggested Repair
Inspect the front end for grease fittings on the lower ball joints, drag link, driveshaft, and sometimes the 4WD linkage; factory parts may use sealed lifetime grease and lack Zerk fittings, while aftermarket parts often have them. For a front-end rebuild, replace all tie rods and the upper and lower ball joints, and inspect the sway bar bushings and end links.
Conversation Summary
The owner of a 2002 Ford F-150 4x4 asked where grease fittings are located after finding two on the passenger side of the front end. An expert said lower ball joints and the drag link have fittings, and the driveshaft or 4WD linkage sometimes do as well, but factory sealed components may not include Zerk fittings, so the truck must be inspected. When asked what a front-end rebuild should include, another expert recommended replacing all tie rods and the upper and lower ball joints, and checking the sway bar bushings and end links.
