1998 Ford F-150 Ball Joint Replacement
ive replaced upper balljoints on a 2000 expediton with 101,000 .
Jan 5, 2006 at 4:25 AM
Thanks for the response, I guess that was my question: At what point can one expect them to wear out under normal driving conditions?
Jan 5, 2006 at 5:32 AM
my 1997 Explorer had both upper and lower ball joints replaced at 120,000 miles...
Jan 5, 2006 at 8:29 AM
really, it all depends on the driver and how well you maintain your vehicle
Jan 5, 2006 at 9:52 AM
I didn mine on a 98 f-150 2000 miles later than you so i would say that is about typical.Make sure you either get lifetime warranty ones or ones with grease fittings most are lifetime and at least you won't have to pay for the parts again.
Jan 6, 2006 at 3:19 AM
Suggested Repair
Ball joint replacement around 85,000–87,000 miles is typical on a similar 1998 F-150. When replacing, use lifetime-warranty ball joints or joints with grease fittings so the parts do not have to be paid for again.
Conversation Summary
The owner of a 1998 F-150 with 85,000 miles asked when front ball joints and tie rods normally wear out under ordinary driving. Other owners reported upper ball joint replacement at about 101,000 miles on a 2000 Expedition and both upper and lower ball joints at 120,000 miles on a 1997 Explorer, and noted that wear depends on driving and maintenance. An expert who replaced ball joints on a similar 1998 F-150 about 2,000 miles later said that timing is typical and recommended lifetime-warranty parts or joints with grease fittings.
