fuel pump issues
LOFASHO00
How you doing i'm having a fuel issue with my truck. I have a 2000 ford f-150 4.6L V8 2WD. It has 87,000miles on it. The truck is a custom truck. I had an air ride system put in the truck for shows. The truck was body dropped 4 inches and bagged. So the truck lays out on the ground with frame. So by doing this i had the gas tank relocated to behind the axle. Well come to find out the person who moved the gas tank swapped the gas tank out with a 2000 chevy blazer gas tank. Well as far as i know chevy doesnt make over a V6 engine. Now my fuel gauge doesnt work. No big deal i can deal with out it. But the truck is have running problems. I replaced spark plugs just dropped a new tranny in it with new clutch. When idle the truck runs fine the moment i put my foot to the gas the truck loses power and will jump back and fourth. I replaced the fuel filter ad well. The only thing i can think of is the engine isnt getting the right amount of fuel. I plug a code reader in and it spit 3 codes. One was the engine was running too lean. 2&3 where cylinders 2&3 were missfiring. Could my problem be that the fuel pump isnt pushing the right amount of fuel and if so do you know what PSI a stock ford fuel pump runs at? I plain on putting a 20gallon aluiminum fuel cell in i just need to find an external fuel pump bt i dont know what a stock ford fuel pump runs at to know which one to buy. Any help would be great. Thanks
Jan 21, 2007 at 2:49 PM
SERVICE WRITER
  • 9,123 POSTS
The spec for yours is 30-45 psi, with the KEy On Engine Off. Ford doesn't specify the KOER spec. NAturally, The Chevy listing appear to be the opposite :?
Jan 21, 2007 at 9:08 PM
SERVICE WRITER
  • 9,123 POSTS
Chevy s10 blaze 4.3- 60-66psi KOEO
Chevy V8 C1500 4.8 & 5.3- 55-62 psi KOEO
Che s10 2.2 -41-47 psi KOER
Jan 22, 2007 at 9:12 AM
