1989 Ford F-150 Fuel Gauge Intermittent
CODYDM
Ford, F150, 1989, 120,000 , 351 EFI. What Would Cause A Fuel Gauge To Work One Day And go Out The Next? I Couldn't Find A fuse for it.
Oct 1, 2007 at 11:14 AM
BLACKOP555
  • 10,386 POSTS
There is a fuse for the instrument cluster and the fuel pump. You could take the tank down and pull out the pump and make sure the wire is not corroded off or the float still moves freely.
Oct 1, 2007 at 1:53 PM
Suggested Repair
Check the instrument cluster and fuel pump fuses. Drop the tank, inspect the fuel pump sender wire for corrosion, and confirm the float moves freely.
Conversation Summary
The owner of a 1989 Ford F-150 with a 351 EFI reports that the fuel gauge works one day and fails the next, and could not find a fuse. The expert says there are fuses for the instrument cluster and fuel pump, and suggests dropping the tank to check that the sender wire is not corroded and that the float moves freely.
