1995 Ford F-150 Front Brakes
SPINNY
I have a 95 F150 4x4 351 with 220,000 miles.
The front brakes (pads/rotors) need replacing, I have replaced brakes on a 2 wheel drive but never on a 4x4.....am I in for a big job? ( It has manual locking hubs)
Thanks
spinny
Apr 11, 2007 at 10:19 AM
BOOTDOG
  • 665 POSTS
if you never done the rotors before it can be kinda tricky. i know you need a special 4 wheel drive socket to remove the nut. just be sure, if you do it yourself, take your time and look for snap rings, clips, key ways and springs inside the hub. get a rag and lay each piece in a row so when you install them back, just start replacing the last piece that came out first and so on. good luck
Apr 11, 2007 at 11:23 AM
Suggested Repair
Replacing the front pads and rotors on this manual-hub 4x4 is doable but trickier than a 2WD job. Use the special 4WD socket for the hub nut, work slowly, and note snap rings, clips, keyways, and springs. Lay the parts out in removal order and reinstall them in reverse.
Conversation Summary
The owner of a 1995 Ford F-150 4x4 with manual locking hubs needs front pads and rotors replaced and has only done 2WD brakes. The expert says rotor work can be tricky, requires a special 4WD socket for the nut, and that hub snap rings, clips, keyways, and springs should be kept in order for reassembly.
