1995 Ford F-150 Front Rotor Specs
SPINNY
1995 F150 4x4 351.
does anyone know what the min. specs should be on the rotor`s?
Apr 13, 2007 at 9:36 AM
TAURUSWHEEL
  • 718 POSTS
Why, do they need to be turned down???? I think it is stamped right on the rotor somewhere, could be under the rust...Machine shop will tell you right off the bat if shaving them will exceed minimum thickness..
Apr 13, 2007 at 11:11 AM
SERVICE WRITER
  • 9,123 POSTS
Discard is at .96 " or 24.45 mm.
My opinion is to replace them if it is a matter of doing the brake job. I found advance auto wearever rotors very reasonable in cost and dependable as any other.
Apr 13, 2007 at 11:49 AM
TAURUSWHEEL
  • 718 POSTS
I'll second the wearevers, I bought some rotors, guardian I think, they were like 9 dollars apiece, worked excellent.. kind of hard to even find a place toturn rotors, most are throwaways, like brake drums.. talking standard issue parts.
Apr 13, 2007 at 1:08 PM
Suggested Repair
Replace the front rotors if they are near or below the 0.96 in (24.45 mm) discard thickness. Check the minimum thickness stamped on the rotor, or have a machine shop measure it before turning. Replacement rotors are a practical option because many shops no longer machine rotors.
Conversation Summary
The owner of a 1995 Ford F-150 4x4 asked for the minimum front rotor thickness. Experts said the discard thickness is 0.96 inch (24.45 mm), often stamped on the rotor, and a machine shop can confirm whether turning is safe. They recommended replacing the rotors during a brake job rather than machining them.
