1986 Ford F-150 Brake Problem
PJASKA
  • 1986 FORD F-150
1986 Ford F150 with 120,000 miles.
Brakes were fine unitl front coil spring broke. Brake light on dash came on and truck was hard to stop. I thought it was because the spring coil was broken.
I replaced front coil spring and brake pads and shocks while I was at it. The pick-up does not stop as before. The brake light stays on and the front wheels will slide when I apply brakes. The brakes just don't work well.
What's wrong?
Sunday, March 12th, 2006 AT 12:40 PM
OLDBAY
  • 9 POSTS
Check to see if the brake lines were pinched or otherwise damaged as a result of the damage or subsequent repair. And bleed the brakes as well.
Sunday, March 12th, 2006 AT 2:39 PM
