F-150 won't run
SPARKSAJ
  • 1915 FORD F-150
I have a 5.0L, ‘86 F150 with 90,000 miles but prior to my recent purchase the engine had been replaced and the vehicle has an electronic fuel injection system rather than a carburetor. Recently the truck died while sitting at a red light and I’ve not been able to get it restarted. The engine will turn over but immediately dies. I’ve confirmed there is fuel to the injectors and there is a spark from the plugs. I replaced the ignition module and fuel pump. I don’t know where to look next.
Saturday, June 30th, 2007 AT 4:03 PM
2CARPRO JACK
  • 11,533 POSTS
Does it keep its spark need to leave one plug wire off to be sure that it isnt losing spark out of crank mode. Use a test light to verify constant ignition power at the coil
Sunday, July 1st, 2007 AT 8:33 AM
