1997 Ford F-150 Won't Idle
SMITTY1224
I have a 97 ford f150 4x4 4.6l 5 speed 98000miles. It starts but will only stay on if my foot is on the gas. My check engine light is on and when i ran the codes it said it was running lean. I've changed the 02 sensors, cleaned the fuel injectors and replaced the gas cap. And now this. I am wondering if it may be the IAC or the mass air flow sensor, but i dont know which one is more likely. please help.
Oct 30, 2007 at 6:04 PM
BLACKOP555
  • 10,386 POSTS
Well first i would like you to clean the MAF sensor with some qd contact cleaner. next you should check the EGR and make sure it is not plugged open with carbon. next check the PCV valve, when shooken it should rattle, if not replace it. also check the rubber boot and the hose for cracks and cuts.
if those are all good then you should definetley clean the throttle body and replace the IAC
Dec 5, 2007 at 12:19 PM
Suggested Repair
Clean the MAF with electronics contact cleaner, confirm the EGR is not stuck open with carbon, and replace the PCV if it does not rattle. Inspect the intake boot and hoses for cracks. If those checks are good, clean the throttle body and replace the IAC.
Conversation Summary
A 1997 Ford F-150 4.6L starts but will not idle unless the accelerator is held, and a scan shows a lean condition. The owner already replaced the oxygen sensors and gas cap and cleaned the injectors, and suspects the IAC or MAF. The expert recommends cleaning the MAF, checking the EGR and PCV, inspecting the rubber boot and hoses, then cleaning the throttle body and replacing the IAC if those items are good.
