2001 Ford F-150 AC Not Cold
NVYARIZ
I have a 2001 Ford f-150 with around 33,000 miles. For the first time of the year we used the A\C today and while it blew air cooler than outside, it did not blow cold air. After about 20-25 minutes of driving it started to cool down a little more but not much. What could be causing this issue and is it something that I can correct on my own?
Thanks
Apr 8, 2006 at 11:00 AM
LOVESCARS
  • 359 POSTS
Refrigerant may need topping off. The normal operation should blow cold air approx 10 degrees below ambient. If it's not hot enough out it won't work right
Apr 8, 2006 at 1:44 PM
Suggested Repair
Check and top off the refrigerant if it is low. Expect vent air about 10 degrees below ambient, and note the system may not cool properly if it is not hot enough outside.
Conversation Summary
The owner of a 2001 Ford F-150 with about 33,000 miles says the A/C blows cooler than outside air but not cold, improving only slightly after 20-25 minutes. The expert suggests the refrigerant may need topping off, notes normal cooling is about 10 degrees below ambient, and says the system may not work right if it is not hot enough outside.
