If you are getting no air flow in any position, whether it is heat or air, then it is probably not the compressor. I would look in the Central Juntion Box and there are two fuses that control the fan. A 30amp fuse that is the fan power, and a 10amp fan blower motor relay power. If it is the fan 30a fuse, I would replace it and see if it blows again. If it does, I would suspect a bad motor.
If it is the 10a control fuse, then possibly the electronic temp control module or wiring.
2004 model, is the warrenty up?
SPONSORED LINKS
Saturday, August 12th, 2006 AT 7:22 PM
