My son's A/C in his '97 (F-150 XLT S/Cab 3 door, Auto/OD, 4.6, 2WD, 215,415 miles) doesn't blow hard out of the ducts/vents. The air is cold but it seems that w/the fan speed on high it blows as if it were on low to medium low (the first notch/click after the selector switch is set to low). The air damper door is operating, I can see it moving when the selector is switched from MAX to regular A/C. I pulled the fan & there is nothing wrong w/the blower/squirrel cage.
Any ideas as to why the volume is not there?
P.S. The A/C is NOT blowing out of the defroster when it is on in any regular A/C position & it sounds very loud under the dash like it wants to blow but very little comes out.
P.S.S. I'm also trying to find an exploded view of the system on line but I can't. Can someone post one please.
Thanks.
SPONSORED LINKS
Saturday, July 21st, 2007 AT 3:41 PM
