A\C Problem
NVYARIZ
  • FORD F-150
I have a 2001 Ford f-150 with around 33,000 miles. For the first time of the year we used the A\C today and while it blew air cooler than outside, it did not blow cold air. After about 20-25 minutes of driving it started to cool down a little more but not much. What could be causing this issue and is it something that I can correct on my own?
Thanks
Saturday, April 8th, 2006 AT 6:00 PM
LOVESCARS
  • 359 POSTS
Refrigerant may need topping off. The normal operation should blow cold air approx 10 degrees below ambient. If it's not hot enough out it won't work right
Saturday, April 8th, 2006 AT 8:44 PM
