86 Ford F-150
BO
  • 1986 FORD F-150
After the truck gets hot and you shut it off, it will not start. After you let it cool down it will start. I have replaced both fuel pumps and the ignition coil.
Thursday, June 7th, 2007 AT 9:53 AM
MICHAEL081278
  • 11 POSTS
Try replacing the ignition module and you should see your problem resolved.
It bolts on to the side of your distributor.
Hope this helps!
Thursday, June 7th, 2007 AT 10:39 AM
