Hi 88, To clarify, this is not the ignition coil that creates the spark. I'm referring to the pickup coil next to the shaft in the distributor. It's pulses are what triggers the module to fire the ignition coil. In particular, check the tiny wires attached to the coil. If you can catch it immediately after the engine stalls, unplug that coil and measure its resistance with an ohn meter. Usually it will measure open circuit when it gets hot.
Caradiodoc
Sunday, March 14th, 2010 AT 3:46 PM
