1986 Ford F-150 wont start
4NGLOFDETH
  • 1986 FORD F-150
  • V8
  • 4WD
  • MANUAL
  • 100,000 MILES
My truck broke down while driving down the road it wont start it will turn over and it will try to hit but wont stay running I can here the fuel pump running for a breef sec after I turn the ignition on and when the ignition is on I can push down the shrader valve on the fuel rail and it squirts gas but not mutch and its just a breif squirt not a constant stream and the distrubuter was loose and I think its a problem between timing and fuel I have checked im getting air and fire so it must be in the timing or fuel andy segetions
ps. Its a fuel injected 302
Monday, September 22nd, 2008 AT 1:28 PM
Do below and tell me what's missing fuel or spark
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil, distributor pick-up coil, ignition control module, cam and crank sensors
Monday, September 22nd, 2008 AT 1:50 PM
4NGLOFDETH
Ok I checked the spark and im getting spark on every wire. I dont have a pressure tester and I checked the fuel rail shrader valve when cranking the engione and a constant stream squirts out im planning to buy a pressure tester tomorrow. I cant hear the injector pulsating and I dont have a tester so ill be picking one up tomorrow as well. Also I had somone crank the vehicle while I moved the distributer slowly and coulnt get it to hit on any cylinder but I have spark.
Monday, September 22nd, 2008 AT 8:33 PM
Check the fuel pressure if its within specs and look for power at the injector/s harness red wire with key in run-do you have it?
Monday, September 22nd, 2008 AT 8:49 PM
4NGLOFDETH
I have power on the injecctors and the fuel pressure is up to spec
Sunday, September 28th, 2008 AT 2:17 PM
4NGLOFDETH
Ive been working with a realitve on this truck and he is a certified machanic and even he is outs segestions everything to run is there but it just wont hit a lick.
Sunday, September 28th, 2008 AT 2:18 PM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module.
Sunday, September 28th, 2008 AT 2:21 PM
