I've noticed a chirping noise coming from the front driver's side wheel
JNEMES
  • 2007 FORD F-150
  • V8
  • 4WD
  • 32,000 MILES
For about 6 months I've noticed a chirping noise coming from the front driver's side wheel. It's not loud, but very noticeable when you have the windows down. I mainly notice it coasting about 20-30 mph, or going through quiet parking lots. The chirping gets faster as the truck goes faster. It almost sounds like one part of the wheel rubs against something every time there is a full revolution. The squeak is comparable to what a cricket sounds like. I thought it was the brakes because the noise stops when I gently apply the brakes, but I had a brake inspection and they said the brakes were only about 1/2 worn. The noise also seems to stop when I turn to the right. Any ideas?
Wednesday, August 18th, 2010 AT 1:16 PM
  • 109,885 POSTS
Based on your description, I feel it is brake related. Even if the pads are good, there is chance the rotor has a slight warp to it and touches the pad in one spot. If it stops when you tough the brakes, that is my first guess.
Tuesday, May 11th, 2021 AT 1:13 PM
