Can't figure out belt squeak
CANDTALWAYS
  • 1993 FORD F-150
  • V8
  • 4WD
  • 166,000 MILES
Hi I noticed a squeak about 3 months ago on my truck so I replaced the serpentine belt. Well it quit for a day or two then it started up again but worse. Took it to a machanic and apperently they just spray some belt dressing on it and it stoped. But then again it started back up after a day or so of driving.I noticed after they sprayed the belt my pulleys and everything are coroded with a greasy film. So i'm assuming this was caused by the belt dressing they put on it. Anyway it still squeaked worse then ever so I replaced the tensioner pulley and the idler pulley and even changed the belt again. It stoped for a day or so but yet again it started squealing bad. Well after that I figured maybe my a/c compressor was going out or something so I replaced my belt with one to bypass the a/c compressor. Well again it stoped and within a few hours of driving it started back up.I've listed to try to pin point where the noise was coming from and it sounds like its coming from the smog pump pulley but i'm not really sure. Do you have any suggestion's on anything to look for and if I should change the smog pump pulley how do I go about keeping the pulley still while I loosing the bolts?Your help is greatly greatly appreciated. Thanks.
Tuesday, February 19th, 2008 AT 7:25 AM
2CARPRO JACK
  • 11,533 POSTS
The AIR pumps will make a ton of noise. Take it off the truck and put a little motor oil in it and work it by hand to lube the insides (bushings and pump vains). Youll see what im talking about when you get it off the truck. Good luck
Tuesday, May 11th, 2021 AT 1:15 PM
CANDTALWAYS
  • 10 POSTS
The smog pump I mentioned is listed as the air pump on the truck.I don't know if they are the same thing but I thought I should correct it just incase. Maybe this will help you a lil more on tryin to figure the problem out and the motor is a 351 w if that helps any. Thanks again
CANDTALWAYS
  • 10 POSTS
Wow fast response thanks alot i'll give it a try and go from there.
2CARPRO JACK
  • 11,533 POSTS
Youre welcome
CANDTALWAYS
  • 10 POSTS
Should I drain most of the oil out that I put in the pump or does it really matter?I think that it did the trick I just want to make sure weather or not to leave what oil I put in it in there or if I should drain it and just leave enough in it to free up everything. And thanks again you have been a big help.
2CARPRO JACK
  • 11,533 POSTS
Let it drain, but dont worry if there is some left in there, it will be pumped out
