2006 Ford F-150 vehicle will not start
TEXAG
  • 2006 FORD F-150
  • V8
  • 65,000 MILES
Attempted to start car, would not start, now with key removed, alarm light on dash is flashing fast, can hear clicking noise from behind/under back seat, no interior lights, will not start, running lights lit very dimly. Battery showing 15 volts. Nothing electrical works, key fob will not operate door locks.
Thursday, April 15th, 2010 AT 7:13 PM
MERLIN2021
  • 17,250 POSTS
Are you testing the battery with an external voltmeter, or the trucks gauge?
Thursday, April 15th, 2010 AT 7:19 PM
TEXAG
Checked with an external voltmeter. Got 15v with battery diconneted. When it's connected voltage is less like something is drawing it down. Also stearing wheel is not locked and can not move shift selector.
Thursday, April 15th, 2010 AT 7:27 PM
MERLIN2021
  • 17,250 POSTS
All fuses checked? There is a tech bulletin for the starter terminal, a new wire harness pigtail kit is out to fix no stat issues for that, but this seems more like a modules, I recommend a scan with a Ford scantool, generics do not read the "B" and "U" codes.
Friday, April 16th, 2010 AT 5:46 AM
