2005 Ford F150 help
2005 FORD F-150
80,000 MILES • V8 • 2WD • AUTOMATIC
RANDYBACCHUSTONYA
hey my truck was working just fine i stoped for gas went into the store came back out pumped my gas and went to drive off and lost cluster illumination lights and tail lights replaced the fuse it was blown fuse works but still no lights it called for a 15amp and i put a 25amp 30amp it blowed them so i put a 15amp back in and it worked but no lights still i have power but no lights....
Feb 24, 2010 at 4:36 AM
  • 110,244 POSTS
Actually, it could be a few things, headlight switch, BCM, ground... However, since you keep blowing a fuse, there has to be a short. I would start with the switch. As far as the fuse size, never use a larger amp fuse that is called for. Remember, you want the fues to blow before something catches fire.
Let me know what you find.
Feb 26, 2010 at 5:41 AM
