2005 Ford F-150 brake lights not working
PERKINSDADDY
  • 2005 FORD F-150
  • V8
  • 125,000 MILES
Brake lights not coming on, signals are ok, no blown fuses?. Truck was in accident, hit left frt. Corner, I had to replace the ABS unit? I have bled it twice. But still have idiot lights on dash - ABS and brake?
Can you help?
Friday, January 25th, 2008 AT 10:09 AM
Brake lights not working
Check the brake light switch -follow the brake pedal till it meets up with brake support the switch should be here-disconnect the connector and use a jumper wire-the brake light should come On. -Check-if so adjust it.
Friday, January 25th, 2008 AT 11:13 AM
