HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Exterior Light
Brake Light
Not Working
1997 Ford F-150 my brake lights dont work, how do I check th
WALLA
MEMBER
1997 FORD F-150
V8
4WD
AUTOMATIC
254,000 MILES
My brake lights dont work my bulbs are all good , my fuses are all good how do I check the brake switch above the brake pedal
Sunday, December 30th, 2007 AT 11:16 AM
MECHANIC
Unplug the two wires and bridge out, turn ignition on and brakes should light up.
Mark (mhpautos)
Monday, December 31st, 2007 AT 5:41 AM
Please
login
or
register
to post a reply.
Related Brake Light Not Working Content
No Brake Lights
Back Light Not Working For Turn And Signal Light. I Replaced Bulbs, Relay, And Switched Out The Back Bulb Component. The Front Light Flash...
Asked by
mamartinez01
7 IMAGES
1999
FORD F-150
Brake Lights Not Working Properly
Okay, With The Parking Lights On And The Key Off The Driver Lamp Is Lit Pass Lamp Not Lit. 2 Parking Lights On With Key On Both Lamps Lit....
Asked by
moshbikes21
1976
FORD F-150
2001 Ford F150 No Break Lights
Brakes Problem 2001 Ford F150 V8 Four Wheel Drive Automatic 2001 Ford Lariat, My Break Lights Dont Work. I Have Turn Signals And...
Asked by
jamieboston
1 ANSWER
2001
FORD F-150
Driver's Side Brake Light Stopped Working
My Brake Light Quit Working On The Driver Side I Changed The Bulb It Still Does Not Work. I Changed The Socket And It Still Does Not Work....
Asked by
David Hall3
1 ANSWER
2004
FORD F-150
Brakes Lights Does Not Work When The Headlights Are On...
I Have A 2006 F150 Xl. My Brake Lights Does Not Work When My Headlights Are On. You Press The Brakes When The Lights Are On And The Tail...
Asked by
ldavidl05
2006
FORD F-150
VIEW MORE
How to Use a Test Light
Headlight Dim or Dull
Turn Signals Blink Fast
