2001 Ford F-150 no break lights
JAMIEBOSTON
  • 2001 FORD F-150
Brakes problem
2001 Ford F150 V8 Four Wheel Drive Automatic
2001 ford lariat, My break lights dont work. I have turn signals and running lights. No break lights though. I have checked and changed fuses, tested and changed my break pedal switch. Yet to get break lights. Could it go into my turn signal switch perhaps?
Tuesday, August 26th, 2008 AT 2:43 AM
KHOOPER
  • 22 POSTS
Check the bulb if they are still in good condition. Then go and test the fuses and be sure to check the grounds see if they no broken fuses. If those two are ok, so maybe the brake light socket is the problem.
Tuesday, August 26th, 2008 AT 2:55 AM
