i just changed my front struts and in the process i had to disconnect my tie rod and upper control arm to get the shock/coil assembly out. now after putting it back together i drove the truck and immediatly noticed a rattling noise coming from aroud the front passenger side wheel. it only does it in 2wd, going forward, and pressing the accelerator. if i let off the gas or put it in 4wd or reverse there is no noise. the noise increases with speed and if i slam on the brake and keep my foot on the gas it gets louder and finally grinds a little and quits. it sounds to me like its tryin to engage in 4wd for some reason. the only explanation i can come up with is something caused by the spindle pulling against the drive axle when i had the upper control arm off of the steering knuckle. im no mechanic though so i wanted to hear what u guys think it could be. thanks for the help.
May 25, 2008 at 4:24 PM
