2001 Ford F-150 won't turn over starter has been replaced
AV8RBILL
  • 2001 FORD F-150
  • V8
  • 4WD
  • 157,000 MILES
My Ford F150 will start sometimes but only when cold. It runs fine but if you turn it off it will not restart. The starter was replaced and I think it's a electrical problem. Is it the relay or what?
Saturday, June 12th, 2010 AT 9:21 AM
CARADIODOC
  • 34,396 POSTS
Hi av8rbill. Welcome to the forum. What does "not restart" mean? Since you replaced the starter, I assume you mean it doesn't crank, not that it cranks but won't run. A common cause of an intermittent no-crank on Fords is loose terminal nuts on the starter relay. The symptom will be a kind of loud clunk is heard when turning the ignition switch to "crank" but the starter won't spin. If you don't hear that clunk, suspect the ignition switch itself or the wiring to the relay. A test light will be the best choice to find the problem.
Caradiodoc
Saturday, June 12th, 2010 AT 2:04 PM
AV8RBILL
I replaced the starter relay and "shorted out" the sysytem and now everything starts just fine.
Saturday, June 12th, 2010 AT 5:01 PM
CARADIODOC
  • 34,396 POSTS
Dandy news. Hope it keeps working.
Caradiodoc
Saturday, June 12th, 2010 AT 8:10 PM
