2001 Ford F-150 won't crank
MARC BOZEMAN
  • 2001 FORD F-150
  • V8
  • 81,000 MILES
Truck will turn over but will not crank. On the dash the theft light blinks. Was running great then tried to start it again wouldn't crank new battery about mounth old. Vacume leak repaired about a mounth ago no other problems.
Monday, September 1st, 2008 AT 10:47 AM
BMRFIXIT
  • 19,053 POSTS
Do u have another key u should try it
check the starter
Monday, September 1st, 2008 AT 9:05 PM
MARC BOZEMAN
Thanks for the replys but someone had tried to start my truck with another key and the theft devise was on but incase this happens to someone else the why to fix it is to put your key in the driver side door and turn the key to the left first then to the right and it will reset the anti-theft devise. Then your truck should crank. Thank again
Tuesday, September 2nd, 2008 AT 8:11 AM
