2001 Ford F-150 Ignition coil
AAVLM
  • 2001 FORD F-150
  • V8
  • 4WD
  • 107,000 MILES
Why would I constantly be blowing ignition coils. I have had numerous times that his has happened.
Sunday, October 26th, 2008 AT 12:56 PM
BLACKOP555
  • 10,371 POSTS
You using a cheap ignition coil?
Make sure you go with genuine motorcraft.
Is there moisture on the coil? Is it near any coolant hoses or areas water can get at?
Could also be that the spark isnt getting to the plug and not properly grounding causing excessive voltage in the coil and it to burn out.
Is it coil on plug, dis or distributed?
Sunday, October 26th, 2008 AT 1:25 PM
