2001 Ford F150 Front End!!!!
96,000 MILES • V8 • 4WD • AUTOMATIC
LUBYTOONS
My 2001 F150 4x4 Supercrew has developed a bad shake in the front end. It only happens between 50 & 55 miles an hour and at first it wasn't too bad but has grown worse. I was told that it was the lower ball joints and the upper control arm sterring bushings. I am not a mechanic nor do I play one on t.v. so I am desperate for a clear answer. Thank you for your time!
Feb 27, 2009 at 2:33 AM
RACEFAN966
  • 5,029 POSTS
Ok first I would have the tires balanced and rotated. See what that does and get back to me and we will go from there.
Feb 27, 2009 at 3:15 AM
LUBYTOONS
Thanks for your answer. I did have that done initally by a tire company that deals mainly with lifted trucks and/or ones with large tires. They replaced the upper ball joints as well as balancing but were unable to resolve the problem. I finally took it to my mechanic who diagnosed the solution I listed previously.
Feb 27, 2009 at 3:28 AM
RACEFAN966
  • 5,029 POSTS
Ok now be upfront with me on this. Is the truck lifted and how much and what size tires? Does the truck have a steering stabelizer or not? I need all the info on the truck so I can better help.
Feb 28, 2009 at 12:13 PM
