Test ignition switch, injectors wont fire if the switch signal isnt present, this can be true even if the lights work. If you can get it scanned with a tool that reads "B" codes, or try this with the dash board, it's called the Dealer test mode:
HYBRID ELECTRONIC CLUSTER (HEC) SELF-DIAGNOSTICS
NOTE: Turning ignition switch to OFF position will cause HEC to exit selfdiagnostics.
NOTE: Instrument cluster is a Hybrid Electronic Cluster (HEC). HEC has selfdiagnostic
system which may store a Diagnostic Trouble Code (DTC) if
a problem exists in the system. HEC DTCs may be displayed on the
instrument cluster.
Turn ignition switch to OFF position. To enter HEC self-diagnostics, press and hold instrument
cluster SELECT/RESET button. Turn ignition switch to RUN position. Within 5-8 seconds, odometer
will display "tESt" to begin self-diagnostic mode. SELECT/RESET button MUST be released within
3 seconds of odometer displaying "tESt". Repeatedly press SELECT/RESET button through odometer
displays until "dtc" is displayed. When odometer displays "dtc", press SELECT/RESET button again
and any continuous DTCs will be displayed before odometer advances to next display. For other HEC
diagnostic modes, see HYBRID ELECTRONIC CLUSTER (HEC) SELF-DIAGNOSTIC
MODES.
If DTC is retrieved, see HYBRID ELECTRONIC CLUSTER (HEC) DTC TEST INDEX table. If
no DTCs related to the concern are retrieved, repair by symptom. See SYMPTOM INDEX table
under SYSTEM TESTS. For DTCs not covered in this article, see MODULE
COMMUNICATIONS NETWORK - F150 LIGHT-DUTY PICKUPS article. Turn ignition
switch to OFF position or press and hold SELECT/RESET button for 3 or more seconds, release to
exit HEC dealer test mode.
INSTRUMENT PANELS - ANALOG - F150 LIGHT-DUTY PICKUPS - CNG -2000 Fo. Page 1 of 1
4/28/2010
HYBRID ELECTRONIC CLUSTER (HEC) DEALER TEST MODES
NOTE: Values displayed are instrument cluster input values, not gauge values.
"GAGE"
Activates sweep of all gauges, then displays present gauge values. Does ROM and EE checksum tests.
If gauge sweep is inoperative, replace instrument cluster.
All Segments Illuminated
Illuminates all odometer segments. If any odometer segment is inoperative, replace instrument cluster.
"bulb"
Illuminates all micro-controlled lamps and LEDs. Replace bulb or LED as necessary.
"r"
Returns to normal operation all micro-controlled lamps and LEDs and displays hexadecimal values
for ROM. This is used when requesting assistance from Ford hotline. If alternating flashes of FAIL
and ROM level are displayed, replace instrument cluster.
"EE"
Hexadecimal value for EE level. This is used when requesting assistance from Ford hotline. If
alternating flashes of FAIL and EE level are displayed, replace instrument cluster.
"dt"
Displays hexadecimal coding of final manufacturing test date. This is used when requesting assistance
from Ford hotline.
"dtc"
Displays continuous DTCs in 16-bit hexadecimal. Pressing SELECT/RESET button will display any
DTCs stored before proceeding to next step.
"enG"
Displays English value speed input to instrument cluster. Speedometer will indicate present vehicle
speed. Display will indicate zero if input is not received, if input is invalid for more than one second
or if actual vehicle speed is zero.
"m"
INSTRUMENT PANELS - ANALOG - F150 LIGHT-DUTY PICKUPS - CNG -2000 Fo. Page 1 of 3
4/28/2010
Displays metric value speed input to instrument cluster. Speedometer will indicate present vehicle
"tAc"
Displays tachometer value input to instrument cluster. Tachometer will indicate present engine speed.
Display will indicate zero if input is not received, if input is invalid for more than one second or if
actual engine speed is zero.
"FUEL"
Displays fuel level input to instrument cluster. Fuel gauge will indicate present fuel level. Displays
255 for open circuit, about 232 for full stop, 215 for full tank, 178 for 3/4 tank, 138 for 1/2 tank, 93
for 1/4 tank, 41 for empty or 0-20 circuit is shorted. Below 55 low fuel warning lamp should light. If
value is displayed between 0 and 20, circuit is shorted. Perform TEST D: TANK TEMPERATURE
SENSOR CIRCUIT OPEN (DTC B1223) under SYSTEM TESTS.
"OIL"
Displays last oil pressure reading input to instrument cluster. Oil pressure will indicate present oil
pressure. Normal oil pressure will display a value between 000 and 176. An inoperative engine oil
pressure switch will display a value greater than 176.
"dEGC"
Displays last coolant temp input in degrees of Celsius to instrument cluster. Coolant temperature
gauge will indicate present coolant temperature. Displays 49 C= cold, 60 C= normal start, 120 C=
normal end, 119 C= temperature warning indicator ON, "-40" C= no SCP message for 5 seconds. If
value is displayed -40 °C, and SCP message for engine temperature has not been received for more
than 5 seconds, go to TEST E: TANK TEMPERATURE SENSOR CIRCUIT SHORT TO
POWER (DTC B1224) under SYSTEM TESTS.
"br"
Displays brake fluid level input to instrument cluster.
"bAtt"
Displays battery voltage input to instrument cluster. Battery voltage gauge will indicate present
battery voltage. Displays 93 - 102=6.9 - 9.1 volts voltage low, 115 - 125=8.5 - 10.7 volts normal start,
215 - 225=15.8 - 18 volts normal end, 230 - 241=16.9 - 19.1 volts voltage high.
"rhEo"
Displays present hexadecimal value for instrument cluster backlight pulse width modulated input to
instrument cluster. This is used when requesting assistance from Ford hotline.
INSTRUMENT PANELS - ANALOG - F150 LIGHT-DUTY PICKUPS - CNG -2000 Fo. Page 2 of 3
4/28/2010
"rhi"
Pulse width modulated input duty cycle to instrument cluster.
"rhS"
Standard Corporate Protocol (SCP) hexadecimal dimming step. This is used when requesting
"rho"
Output driver counts in hexadecimal format. This is used when requesting assistance from Ford
hotline.
"Cr"
Displays present RUN/START sense input to instrument cluster. Shows -h with ignition switch in
START position and -L with ignition switch in RUN position.
"ALtF"
Displays 8-bit hexadecimal value for alternate fuel level. Shows -- if message not received and FF if
message invalid. Perform TEST J: NO COMMUNICATION WITH NATURAL GAS VEHICLE
(NGV) MODULE under SYSTEM TESTS.
"PA-PE7"
Is not used for display.
"GAGE"
Repeats test display cycle.
INSTRUMENT PANELS - ANALOG - F150 LIGHT-DUTY PICKUPS - CNG -2000 Fo. Page 3 of 3
4/28/2010
SPONSORED LINKS
Wednesday, April 28th, 2010 AT 1:05 PM
