Cranks but will not start
150,000 MILES • 4.2L • V6 • 2WD • AUTOMATIC
DEBBIE MACK
My truck will turn over but will not start. I have checked the fuel pump, fuel pump relay, fuses, I am getting .4 volts from the fuel pump relay to fuel pump. Can you give me any suggestions on what to check to get this truck to start? Once it is running, it runs great but just cannot get it to fire.
Dec 16, 2016 at 3:50 AM
HMAC300
  • 48,601 POSTS
try a security code reset then check relay for corrosion or bad contact relay may not be getting enough voltage. could be an ignition switch but I kind of doubt that see link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Dec 16, 2016 at 4:40 AM
DEBBIE MACK
Thank you HMAC300. I will check that.:)
Dec 16, 2016 at 6:24 AM
