Your flywheel may bee too thin from the machining, which can cause it to get hotter which can cause what you describe. If they didnt replace the disc/pressure plate last time(when they machined flywheel) it may be part of the problem too. Be sure the mounts arent torn up from this problem, it is very hard on motor/trans mounts
Wednesday, May 12th, 2010 AT 9:26 PM
